NEw to the "staggered" setup thing...what ever
Old Jan 31, 2013 | 05:24 AM
Eviljokersti's Avatar
Default NEw to the "staggered" setup thing...what ever
So i have been toying with the idea of getting new rims, but as most people know the really good ones are expensive as hell and the cheap ones are well...cheap. So for the time being i'm going to stick to the stock AP2v2's that are on right now, which i think are the nicest stock wheels to come on any honda I've ever seen. Coming from a subaru and evo I've always had a square set up, so staggered never was a thought in my mind. My 06 has mismatched front and rear tires at the moment and its starting to bother me. After reading about the staggered vs. squared setup, I only came across people going with after market rims for square set ups, which render the best results for handling on and off the track.
Is it possible, (Flame suit on), to buy and mount a pair of the 17x8.5 V2 rears on the front? I know probably some fender rolling will be required, thats not my question. My question is can it be done. Is there something with the hubs that would prevent this? or the offset? I only came up with this Idea on my drive to work this morning. and plan on trying to fit the rear wheels to the front when i get home and see how it goes.
and a little extra for you guys. (I know they are both new but which do you like). These will be going on the stock rims. which would you prefer
A>
http://www.tirerack.com/tires/tires....0&autoModClar=
B>
Old Jan 31, 2013 | 06:08 AM
Moddiction's Avatar
Former Sponsor
I believe you have to bore out the wheels or something to make them fit. People have done it though. I'm someone else will chime in with more info.
Old Jan 31, 2013 | 06:21 AM
1nate7's Avatar
You could run rear 8.5 all around with 245 tires and no rubbing, some track and auto-x guys do this. The hub bore is larger on the front, so you would have to bore them out from 64mm to 70mm. If this a street car only, there really isn't much upside IMO.
I'd go with A, that's just my personal preference.
Old Jan 31, 2013 | 06:31 AM
I daily drive it but when the season comes around I'll be hitting up the glen and E-town, leb valley, etc. for some road coarse, autox events etc. Working on getting my SCCA cert this year.
Old Jan 31, 2013 | 07:23 AM
MMisencik157's Avatar
Its not that hard and plenty of people do it. The only trick part is finding someone local to bore the centers out.
In my opinion a 17x8.5 is too narrow as you'll most likely find that you want to run a 255/40 all around. If you want to run a square setup there are plenty of good 17x9 wheels for about $1,000 or less. I sold my OEM AP2V2s for $600 and Ive seen them sell for much more. Or you could keep them with cheap street tires and run some ZII, Rivals or other EPS tires on the 17x9s for your performance setup.
If you're going to put one of the two tires you posted on your stock wheels and daily them you should go with the ZII as its a better all around tire. The Rival is tuned specifically for dry performance.
Old Jan 31, 2013 | 07:31 AM
The boring out isnt an issue i can due that myself. So basically the rear bores are 64mm and the fronts are 70mm? I'm doing a search now for the exact specs. Now to find some v2 rears lol
I was thinking the ZII's also for there all around performance but damn do i like the look of the rivals, lol
Old Jan 31, 2013 | 03:36 PM
Thats my argument is that for you to buy two rear V2s will be a struggle and pretty expensive. I like having at least 2 sets of wheels with tires for dry on one set and wet on the other.
Old Feb 1, 2013 | 08:19 AM
spa01s2k's Avatar
Depending on what size tire you will use, you may want to consider using a spacer in the front as well. I have 17x8.5 NSX wheels on the front, they are +60 with 255/40 and I was rubbing on the inner fender. OEM S2000 rears are +65. I have since put a 3mm spacer on, I have less rubbing (not completely gone). Originally I was on Tein S-Tech springs (1 inch lower than stock).
volcomboy390
Feb 25, 2014 01:44 PM
GomezWvC
Apr 26, 2012 03:01 PM
HighwayStar
South Florida
Jun 25, 2008 09:15 PM
asiantrick
Sep 17, 2007 07:25 PM
S2Kay
Sep 3, 2003 02:35 PM
