nsx spec question
Old Feb 11, 2009 | 05:37 PM
ap1skee's Avatar
Default nsx spec question
i want to order wheels but i was wondering if nsx spec would rub cause my car is slammed lol and pic request if you can thnx guys
Old Feb 11, 2009 | 05:40 PM
AP2's Avatar
AP2
i would say yes if your not rolled
Old Feb 11, 2009 | 05:57 PM
silentdancer's Avatar
wrong section. what wheels do you want? just stock NSX wheels?
Old Feb 13, 2009 | 12:48 PM
s4play's Avatar
I think you need to be more specific what year/model NSX wheels are you talking about first?
If you are referring to the late model 2002+ NSX rims, they are nearly PERFECT offsets for the s2000 and require nothing but direct bolt on. You do need to change the tire sizing to match the s2000 fitment and amazingly OEM s2000 tire sizes work. I'm running this exact setup right now on my s2000 (see below)
I added a 15mm front spacer to give it a more aggressive offset however since the OEM NSX offset is actually 5mm LESS AGGRESSIVE than the OEM s2000 offset, read more on this thread:
https://www.s2ki.com/forums/index.ph...=639691&st=100
The NSX oem wheels are TRUE BOLT on affair, needs NOTHING to fit perfectly in the rear.
The fronts are 17x7 (exact same size as s2000 oem) but the offset is 5mm LESS AGGRESSIVE meaning they tuck in 5mm more than the stock oem's.
OEM NSX front is +60mm and the OEM s2000 front is +55mm
I already have a set of H/R 15mm spacers with longer studs installed up front so:
1) OEM NSX front will be 10mm more aggressive closer to fender
2) OEM s2000 front wheels will be 15mm more aggressive closer to fender
Old Feb 13, 2009 | 01:26 PM
MugenAP2's Avatar
Even Mugen M7's and MF10's will fit!
TheS
Apr 16, 2016 07:52 AM
BeachBumS
Sep 6, 2006 12:14 PM
brcmboy
May 24, 2004 12:54 PM
Hondafan
May 21, 2002 05:48 PM
XXXRacing
Feb 6, 2001 09:57 PM
