OE Porsche tires on S2000
Old Aug 22, 2002 | 09:38 AM
PLYRS 3's Avatar
Default OE Porsche tires on S2000
curious as to what the tire gurus think of this.........
in the same fashion as there is a SPECIFIC S-02 available for the S2000, there is also an OE Pirelli P-Zero avaliable for the boxster (not sure if the designation is N1, N2, but it's something to that affect)..........
could these be used on the S2000????
i ask as these are 18" OE tires for the porsche and i am looking for 18" replacements for my S-03's........
the sizes quoted are 225/40/18 and 265/35/18 (i'm fully aware that the rear is 10mm wider than recommended on my 18x9 rear wheel for the S2000, but the measured section width was quoted as being only a scant .2 inches wider than a 255 S-03)
i will NOT have rubbing issues up to an additional .4 or so........
there's also some other tires that are OE on ferraris and 911's that have sizes that could work as well..........
thanks all.....
Old Aug 22, 2002 | 02:17 PM
S2kRob's Avatar
Run 'em. They may however be a different compound than the Honda S-02's. I remember at some point Porsche guys referring to them as N1, N2, N3, not sure what it all means, may want to look into it. But if they fit, I'd run 'em.
Old Aug 23, 2002 | 10:07 AM
Phantom's Avatar
What is your offset on the rear 18x9? I hope it is close to +65mm...you will need the high offset to run 265/35/18.
By the way...are you a clutch dropper?
With the additional weight, grip, and overall diameter, the 265/35/18 will have a negative effect when drag racing. Your diff. might not be able to handle it.
Old Aug 23, 2002 | 10:40 AM
PLYRS 3's Avatar
[QUOTE]Originally posted by Phantom
[B]What is your offset on the rear 18x9?
Old Aug 23, 2002 | 10:47 AM
Unicron's Avatar
How many fingers can you put inbetween the tire and the fender with your 255's?
If it is less than a loose 1 finger...I would definately not try the 265's.
If you can fit 2 fingers...265's might work...but don't take my word for it.
The comptech s2000 had the work wheels at one point.
265/35/18 TA KD's...with 18x9 +60mm. I remember they reported some rubbing.
Old Aug 23, 2002 | 11:39 AM
PLYRS 3's Avatar
[QUOTE]Originally posted by Unicron
[B]How many fingers can you put inbetween the tire and the fender with your 255's?
Old Aug 27, 2002 | 07:51 PM
wanabe's Avatar
a friend just bought a 911...
complete with s02s! (was i surprised!)
i assume that they arent the same size as ours, but have not checked.
Old Aug 28, 2002 | 08:09 AM
PLYRS 3's Avatar
Originally posted by wanabe
a friend just bought a 911...complete with s02s! (was i surprised!)
Porsche OE S0-2's are available as well
(as well as the above referenced pirellis)............
Old Aug 29, 2002 | 07:05 PM
jicarro's Avatar
My 911 used to wander and follow grooves and cracks. Very annoying. Problem vanished when I swapped the PZero's with S03's. The Rosso Asimetricos might behave differently though.
Old Aug 29, 2002 | 08:36 PM
ccarnel's Avatar
Just got mine in TKG26. I drove to kingsport today with them on and like them 10xxx better than the pirelli's Dont get me wrong the pirellis are great but the s02's in the N1 porsche designation have very square shoulders in the rear. Anyways I felt the corner adhesion to be very good.
