Offsets questions........from my experience.....
Old Sep 12, 2006 | 03:39 PM
kentarou's Avatar
Default Offsets questions........from my experience.....
Ok, I have a set of XD-9, and my wheel specs are : 17x7.5 +50 w/215/45/17 tires in the front and 17x8.5 + 42 w/245/40/17 in the rear
My wheels look too far "in", and looks like it still have lots of room between the tire and the fender from rubbing.......
Been thinking about this for the last couple days, since OEM is +55 and +65
the rear # is bigger than the front # by 10
+55 +65 = +10 <---- OEM
+50 +42 = -8 <---- Mine
Since I don't have a choice for the rear, so the rear has to stay @ +42
Should I change my front to +42 too, just to get back closer to OEM's +10 ???
Or use a 3-4mm spacer??? Since +42 might rub in the front if my car is lowered??
From my understand, stagger is so important to S2ks, since tire size doesn't change when I changed rims, then I don't think I should change the offsets of
my wheels that much +65 - +42 = 23mm
I don't think my car handles as well as I was using OEM rims
My rear tends to break loose way easier than before
any help or suggestion will be great !! Thanks guys
Old Sep 12, 2006 | 04:24 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Post this in "Wheels & Tires" Forum.
mknightx
Feb 16, 2011 07:05 AM
TicketMagnet05
Sep 20, 2009 09:43 AM
macdaddies911
Jul 7, 2008 05:32 PM
kentarou
Sep 13, 2006 11:14 AM
S2Kay
Mar 4, 2003 06:03 PM
