pattern and size
Old Jan 8, 2010 | 08:31 AM
formulared006's Avatar
Default pattern and size
5X114 is oka to run on ap2 correct? thanks
Old Jan 8, 2010 | 09:44 AM
Tripleblackap1's Avatar
I would suggest reading the wheel fitment guide at the top of the wheel and tire section.
Yes the bolt pattern is 5 on 114.3
Order wheels and tires from someone that can help you understand all the variables. As the s2000 has high offsets that can make choosing wheels that fit frustrating. Good Luck!
Old Jan 8, 2010 | 10:47 PM
looking at prodrive pff7 wheels for the s2000. i know these were made for the wrx, will these fit on an ap2? 18x8 +51 5x114 all around. any info greatly appreciated. i have read the wheel fitment guide was just hoping for a solid word from someone on here. thanks
Old Jan 8, 2010 | 11:50 PM
rioyellows2k's Avatar
Depends on tire size and how low you are. Additionally, anything wider than a 255 is going to look silly on 8" wide rim.
Old Jan 9, 2010 | 09:10 AM
i would probably keep it to a 245 wheel size. I will be lowered about an 1.5 inches. should i put spacers in the back? should i adjust camber or will i have to roll fender and relocate bumper tab? thanks for the help guys
Old Jan 9, 2010 | 11:54 AM
Jim@tirerack's Avatar
Former Sponsor
The WRX does have a different center bore so unless you can get rings and different lugs they are not going to work well. You also need to make sure they have a wider rear wheel. My guess is they don't because they were for the 4 wheel drive car.
spa-zz
Jan 31, 2026 02:22 PM
scubadiver59
May 4, 2013 06:35 AM
wizwalker
Aug 6, 2011 11:21 AM
tylergentry00
Sep 17, 2009 07:23 PM
gotswap
Dec 6, 2005 02:37 PM
