Please HELP!
Old Sep 21, 2009 | 06:45 PM
H.O.C's Avatar
Default Please HELP!
I need professional help with this please! I don't know nothing about wheel spec.
I like this set of wheels a lot, It's called Sport Max 006, 18x8.5 front, 18x9.5 rear +35 offset. I've also had my rear fenders rolled and I'm running neg 2 camber in rear. First, will those fit? Second, what tire size for the rear if they fit? Can i run 285 narrow?
Old Sep 21, 2009 | 06:52 PM
Crisgo's Avatar
Damn. I am not a expert on offset and tire size combo but I will say you will have some rubing or contact issues with that offset and tire size. I would do a bit more off researching. It can possible be done but depends on drop and camber settings. Good Luck!
Old Sep 21, 2009 | 07:23 PM
1nate7's Avatar
There is no way you can fit a 285 with that offset. 225/255 is about the widest you can go, you need a slight stretch or more negative camber with that aggressive offset.
Old Sep 22, 2009 | 10:41 AM
Jim@tirerack's Avatar
Former Sponsor
I agree with the wheels you have the 255/35R18 is the widest that is going to fit without a widebody kit.
Old Sep 22, 2009 | 12:50 PM
H.O.C's Avatar
Ok Thanks guys! So 255 is the widest, alright can I run 225/35 front and 255/30 back? and will the tire be narrow? cuz i like it narrow
upncomin93
Aug 24, 2015 08:21 AM
dirttys2k
Nov 1, 2012 11:54 AM
GPWonTan
Sep 17, 2008 12:49 PM
DoubleOh2000
Oct 8, 2007 11:25 PM
Tuanster
Jun 6, 2007 06:18 PM
