Will this fit in front ? 17X7 42mm offset
Old May 31, 2007 | 05:26 PM
Tuanster's Avatar
Thumbs up Will this fit in front ? 17X7 42mm offset
I think the offset for the front has to be 48mm minimum for 17X7 rim. But just checking to see if I can get away with it. BTW..planning running stock tire size. Thanks.
Old May 31, 2007 | 05:34 PM
gotswap's Avatar
https://www.s2ki.com/forums/index.php?showtopic=342793
I am sure a skinny tire and/or camber would help.
Old May 31, 2007 | 06:17 PM
BSeriouS's Avatar
it all depends on ride heighth.
215s are very doable stock. Once lowered, throw some camber into play and your set.
Old May 31, 2007 | 06:21 PM
2HOTS2k's Avatar
I have 17x7 +38 FRONT, lowered with STECHS. 215-40-17 Tire.. Fits fine with 2 inches gap from Fender to the tires...
Old Jun 1, 2007 | 08:41 AM
Tuanster's Avatar
^ O.K so it may work then . I am only planning to lower it 1" with Eibach pro.
Old Jun 1, 2007 | 09:01 AM
aggie's Avatar
I run a 215 tire with 48 offset and it look close to me.
Old Jun 6, 2007 | 03:46 PM
kuni's Avatar
Should fit with no problem with a 215
Old Jun 6, 2007 | 06:18 PM
AP2's Avatar
AP2
Im running a 7.5 +40 with a 225 up front...
Syn
Jul 29, 2010 08:34 PM
MickeyS
Apr 29, 2010 05:04 PM
H.O.C
Sep 22, 2009 12:50 PM
ASpec818
May 23, 2009 04:42 PM
S2KSim
Feb 16, 2009 09:09 AM
