Please HELP! Will these fit?
Old Jul 31, 2004 | 04:18 PM
C4SxM5's Avatar
Default Please HELP! Will these fit?
Can someone let me know if these will fit if my S2K if lowered 2+Inches?
Old Aug 1, 2004 | 11:12 AM
C4SxM5's Avatar
Can anyone find out if this will fit? I'm trying to buy a used set and would love any info.
Thanks
Old Aug 1, 2004 | 12:35 PM
**Jay-V**'s Avatar
They'll fit, but why would you want 17x7.5 all around? It will look wierd.
Old Aug 2, 2004 | 12:04 AM
dispader's Avatar
Old Aug 2, 2004 | 04:48 AM
natedoggs2k's Avatar
It would also affecting handling/performance of the car. The rear tires should be wider than the front.
Old Aug 3, 2004 | 10:24 AM
dut's Avatar
dut
- yes it will fit, but get 8.5 for the rear.. +50 for the rear will be fine as well..
Old Aug 3, 2004 | 10:39 AM
Jim@tirerack's Avatar
Former Sponsor
I agree that the handling would not be as good with the same size on all four corners. I suppose you could run 205/50R17 front and 225/45 R17 rear with the 17X7.5 all the way around. You would end up narrower than the stock OE rear tires though.
If I can help let me know.
Jim 877-522-8473-364
Old Aug 3, 2004 | 10:45 AM
dut's Avatar
dut
- I have 17x7.5 and 17x8.5 fronts are +48 offset and rear is +50 offset... Volk te37s by the way...
- I am running 215.45.17 and 245 40 17... I am DUMPED to the dirt and my front rubs a little...
- so you should DEF. be okay with a +50 offset because I don't know anyone that would lower their car as much as mine...
Old Aug 3, 2004 | 02:45 PM
C4SxM5's Avatar
thanks for the reply. I was actually offered those wheels and decided to wait for a better set of Volks. If anyone wants to let theirs go, please PM me.
Old Aug 5, 2004 | 04:43 AM
aklucsarits's Avatar
The four 17x7.5" +50 wheels would be fine. Just make sure to run staggered tires. 215/45/17s F and 245/40/17 R should work well.
If you went to 8" wide in the rear, the extra 1/2" of wheel in the rear will only give you about an extra 1/4" of contact patch.
Andrew
David_T
Apr 13, 2009 02:57 PM
S1LV3RS2K
Apr 23, 2008 06:45 AM
shox
Feb 26, 2007 08:25 AM
nureulwihaesuh
Sep 6, 2004 08:38 AM
CeleSaga83
Mar 30, 2004 09:35 AM
