Powder Coating Info
Old Feb 22, 2002 | 09:35 AM
bentrim's Avatar
Default Powder Coating Info
Powder Auto Prices
Prices include blasting of paint/plating, 2 stage iron phosphate conversion coating and powder coating.
Prices for in-stock colors only, add 10% for clear coat (required for metallics and some wrinkle finishes for UV protection).
For non-stock colors, add $15.00, stripping of powder coated surfaces is not included in these prices. Minimum powder stripping charge is $25.
All parts must be disassembled and able to withstand 400 degrees Fahrenheit.
Valve Covers $35.00 ea.
Wheel $50.00 ea.
5-7 day turnaround
Is this a good price?
Old Feb 22, 2002 | 10:46 AM
Phantom's Avatar
$50 per wheel is right about average there bud...
Old Feb 24, 2002 | 06:33 PM
iispms's Avatar
I paid $60 a wheel....he did all the prep work.
I removed the old tires.
Old Feb 25, 2002 | 12:59 PM
Jim@tirerack's Avatar
Former Sponsor
Be careful with powder coating. The heat that is used can soften the wheel. We had a customer that powder coated an SSR wheel and didn't tell us and we took the wheel back because they were bending. SSR tested the wheel and found that the heat was the cause. If the powder coater is not careful with the heat you can have a problem.
Jim
Old Feb 25, 2002 | 01:01 PM
iispms's Avatar
Jim,
Have any idea what temp range to stay under when powerdercoating? I was under the assumption that all wheels were powdercoated instead of painted these days.
Old Feb 25, 2002 | 01:31 PM
Former Sponsor
I do not have any idea what the limit is. You are correct on the wheels being powder caoted but if they don't keep an eye on the time and heat they can damage the wheel. Also the SSR wheel is heat treated which causes a problem.
I hope this helps
Jim
roca136
South Florida
Mar 17, 2008 04:58 PM
watchdogd
Jan 19, 2008 07:26 AM
apex factor
Sep 12, 2006 01:08 PM
