problem running 245/50/16 instead of 45/16?
Old May 8, 2003 | 08:14 PM
SAIYAJIN's Avatar
Default problem running 245/50/16 instead of 45/16?
I ordered the avs es 100s in 50/16. Am I going to have problems with +49 offset wheels with this one?
Thanks guys.
Old May 9, 2003 | 12:55 PM
Unicron's Avatar
Why did you go 245/50/16?
The overall diameter will be bigger.
If you are lowered, you have a good chance of rubbing with +49mm offset.
Old May 9, 2003 | 03:12 PM
SAIYAJIN's Avatar
I thought our oem tires were 225/50/16. Is this not true?
Old May 9, 2003 | 04:30 PM
S2K1's Avatar
The stock tires are 225/50-16 and have the contact patch of a 245/45-16 tire.(*Read Correct Rear Tire Size at top of this forum*). It may rub a little bit, but I don't think it'd be too bad.
Old May 10, 2003 | 12:51 PM
Jim@tirerack's Avatar
Former Sponsor
The 245/50R16 is just about 1" taller than stock. On top of speedometer and odometer error I am pretty sure the tires are going to rub. You also will be gearing the car differently.
It is not a good thing.
Jim
Back S2k
Apr 17, 2009 06:34 PM
dmw16
Jan 5, 2007 09:43 AM
nalVle
Aug 3, 2005 10:12 AM
sonne
Oct 6, 2001 07:33 AM
Scot
May 18, 2001 07:57 AM
