proper offset for rota slipstreams
Old Oct 20, 2006 | 05:58 PM
samvegas's Avatar
Default proper offset for rota slipstreams
im about to lower my '02 with neuspeed sport springs, so drop is about an inch and a quarter. i need to know the proper offset needed for rota slipstreams in 16x7 and 16x8 that will keep the wheel as close to the fender as possible w/o rubbing. tires i am reusing are are 205/55/16, 225/50/16 fuzion zri
also, is it true that the rear factory s-03's in 225 are basically equivalent to a 245? if so then i guess my fuzions need to be upgraded to 245/45/16
Old Oct 24, 2006 | 06:37 AM
IIGQ4U's Avatar
Hi,
What offsets are offered in the slipstreams?
The general consensus is that the factory Bridgestones are the equivalent of a 245 tire and that replacements should be in the 245 size.
Old Oct 24, 2006 | 07:02 AM
FormulaRedline's Avatar
As big as you can get if I remember correctly. I think its +45 on the 16x7s and +48 16x8s.
Old Oct 24, 2006 | 09:57 AM
IIGQ4U's Avatar
Are you using these wheels for track or daily driving? You should be fine on the rubbing so long as you don't slam your car.
Old Oct 24, 2006 | 11:00 AM
SuzukaS's Avatar
you are correct. that is what i have on mine. i cant say on the lowering part yet, i havent had time to put my Eibach's on but i highly doubt i'll rub with them at all. i think you'd have to have coilovers to rub.
Old Oct 24, 2006 | 06:23 PM
samvegas's Avatar
thanks everyone. looks like ill be ok on the street with +45 front and +48 rear with my neuspeed sports
droptopf22
Aug 31, 2011 06:02 AM
slowr6
May 2, 2009 05:12 AM
jacksonjw81
Oct 23, 2008 07:24 AM
pho-shizzle
Dec 3, 2007 05:59 AM
SAIYAJIN
May 10, 2003 12:51 PM
