Pros/Cons non-staggered wheels
Originally Posted by tekka01,Jun 5 2007, 02:06 PM
The rest is bad you say? Why is it, then, that some of the fastest drivers on this board run non-staggered? Pretty bold statement imo, you might want to back it up.
Its more of an advanced driver setup, but I don't think the nomal person is going to notice the difference, except the wonderful ability to rotate the wheels.
Here Rob may provide you with more info....
http://maxrev.net/index.php?location=widetires.htm
Your car looks great by the way!!! saw it at the oyster BBQ but didn't get a chance to say so.
^ I completely agree!
The handling characteristics with a staggered set up lean towards what most people would consider a novice safe (well safer) set up, when going with a non-staggered set up the car will become more twitchy (more over steer) and will require more driving ability to control safely (talking more about at the limit)
If you are using it for driving and looks it does not matter what you run (staggered or non-staggered) with the non-staggered I would be cairful in wet and semi-wet conditions
depends your goal with the car, i doubt you'll need more rubber in front for brake and more turn in for the street.
for 90percent of owner, a rear baised staggered set up proven to be safer/easier to drive.(esp on the tail happy ap1)
Its all in what you do with the car. If you track the car it depends all on the track. A wider wheel up front would cause the car to turn slower because of the added weight, which would suck on a small tight track. I run S.C.C.A. and N.C.C.C. with our vette and on small tight tracks we run the staggered setup so the car can turn "quicker" and on longer tracks with more stretched out corners we use the wider tires up front so we can maintain higher speed with the extra grip. haha well thats my 2cents.
Thanks for the complement.
Originally Posted by RED MX5,Jun 5 2007, 02:27 PM
Dumping the stagger without doing additional suspension tuning is going to yield excessive oversteer.
