Question about Rotors for Jim
Hi Jim,
I'd like to tap into your expertise, as searching the forums isn't helping too much at the moment.
In the past, for HPD, I used OEM rotors with high temperature pads. However, with the rising cost of metal, it appears that I can get aftermarket rotors for similar, if not less than I can get the OEM rotors.
I'm eyeing the brembo rotors for the s2000 at the moment, as I've always had a good experience with their products on my STi, but Tirerack categorizes them as a "premium" rotor, which is not for track use.
I'd prefer to have a solid rotor as opposed to a drilled and/or slotted rotor; can you provide some feedback for me on the Brembo rotors please?
Link to the specific rotors I am interested in:
http://www.tirerack.com/brakes/brakes.jsp?...lar=&perfCode=P
I would be bedding the new rotors with Project Mu HC+ pads.
Thank you!
-Mike
Note to mods: I realize that this would probably be more appropriate in the Parts and Modifications section, but I posted this here because this would be the section Jim frequents the most. Please move if you see that as appropriate!
Thank you!
-Mike
Originally Posted by psychoazn,Sep 10 2008, 06:44 PM
Hi Jim,
Thank you!
-Mike
Thank you!
-Mike
These might even be better:
http://www.tirerack.com/brakes/brakes.jsp?...lar=&perfCode=A
You may want to look at the Cryo Stop Rotor. They are going to give more consistant braking and they will resist cracking, warping and fading. They can also last 3 times longer than a not cryo treated rotor.
I do have a set of the plain Brembo's in stock that would work as well.
If I can help let me know.
kaansahbaz
Feb 12, 2007 09:37 PM
bluesaint
Jun 30, 2006 09:53 PM
