Question for offset guru's
Old Feb 10, 2007 | 05:42 PM
BB_S2K's Avatar
Default Question for offset guru's
I'm thinking about getting wheels that are 8.5" +40 offset for the rear. I did a search and the response sounded like it wouldn't work.
But from the Wheel Fitment Guide it sounds like it would:
[QUOTE]
We'll assume the owner has had a proper alignment, uses tires recommended for the chosen wheel width, and hasn't modified their fenders.
These are minimum recommended offsets. You can use a higher offset if you want, and you will get additional fender clearance.
For the rear:
7.5
Old Feb 10, 2007 | 05:55 PM
CaptainMike's Avatar
Obviously clearance will be decreased with a drop, you will probably have to roll fenders to fit those with any kind of drop, and you'll still be stuck running narrower than stock tires.
Old Feb 10, 2007 | 05:57 PM
velocityracer's Avatar
your sacrificing the the width of traction with a 235 tire......you can get a high offset and put more tire to the ground with a 245+ tires....but i guess you could get this setup
Old Feb 10, 2007 | 07:44 PM
Ubetit's Avatar
You'll have to make so many adjustments to run those. I'd look for some better fitting wheels.
Carsun757
Jul 1, 2016 06:12 PM
armodis
May 1, 2012 04:19 PM
RichV
Mar 13, 2010 03:45 PM
davidc1
Jun 29, 2009 09:09 PM
preeeeluuude
Aug 28, 2007 08:41 AM
