wheel offset question
I found a set of wheels that i really want in non staggered sizes. 18x8 all around. They have 3 offsets available. +45 (perfect for the front) +37, and +25. I know I could stagger the tires 215 or 225 for fronts, and probably 245s on the rear. how do you guys think this would look?
Would a 18x8 +25 offset wheel in the back with a 245 tire look good, or even the +37 offset in the rear? I know 25 mm=1 inch, but i also know that 20mm of offset difference does not equal 1 inch in wheel width.
What do you guys think??
Anyone doing this or should it be done?
+25 is not going to work with out over fenders. +37 will require a roll, maybe a pull, and lots of negative camber. +45 all around is what Enki Rfp1's come in, and lots of guys run those.
Why do you want non staggered 8" wide wheels? I would at least go with a 8.5 or 9 for non staggered. Just my opinion.
Maybe someone else will help more...
18x8 is all they offer, no 18x9 unfortunately. I thought the +25 would be too much, but thought the +37 could possibly work. i will probably go another route though.
Thanks guys!
Thanks guys!
