r888 toyo Problem
Old Oct 26, 2008 | 08:04 PM
s2kwhitepanama's Avatar
Default r888 toyo Problem
Hi everybody well i just have like 2000km with my r888 and the rear ones are SLICKS and the front are almost complete , well i not going to tell my mom hey my rear tires are ended , she is going to kill me and the tire is so endend that is in the metal part well for my security i am going to buy tomorrow the new rear tires for a while , but this is normal that this tires finish to early or there is a problem in aligment or on my driving .
Old Oct 26, 2008 | 08:13 PM
dat boi's Avatar
how is the wear? is it even? do you do any track days?
Old Oct 26, 2008 | 08:24 PM
well this weekend i just went mountain running or winding run to a place called el valle in Panama , it was the first time in 3 months that i take the car to a trip like that , i put 600km in a week , all the weekend i was taking corners , i dont do track days but , i take a lot of curves in the city and also rolling start.
Old Oct 26, 2008 | 09:10 PM
-outkast-'s Avatar
for one, these are r compound tires. from the sound of it, it doesn't look like u know what that means.
i would do a bit more research. ur tires are not street tires, they are competition tires. due to the compound of the rubber, they are not meant to last. if you want tires that will last, i would look into other brands/models of tire.
since u don't do any track days, you are not seeing the full potential of these tires. some aggressive street tires should suffice for what you use the tires for.
Old Oct 26, 2008 | 09:11 PM
dat boi's Avatar
well 2k km still sound too little for all of that wear...get an alignment...are you lowered?
Old Oct 27, 2008 | 12:02 PM
INTJ's Avatar
R888, not a street tire, not that great of a track tire. 2k km would be fine for these, given that he has no idea what he is doing. Are they worn to the side grrove or to the base of the tread elements? Which tred compound?
Old Oct 27, 2008 | 03:18 PM
235 - 17 - 40 well i found the problem is that i like to acelerate to much the first 1 gear and 2 gear when the green light open and my driving is to aggresive also well today i bough the both tires 200$ but is a short term solution for the moment because next tire is going to be a all season something like t 1 r or potenza.
Old Oct 30, 2008 | 10:04 PM
CooperS2K's Avatar
how does that make any sense? you like to accelerate too much on a RACE COMPOUND TIRE. You sure youre not doing burnouts up and down the road? Maybe beating on those ls1's burned them up....
Old Oct 30, 2008 | 10:08 PM
Stealth_SUX_'s Avatar
I think you may need to lay off the donuts and burnouts..
Old Oct 31, 2008 | 07:38 AM
INTJ's Avatar
or just put on some bfg gforce.
