Rear Wheels "Wobble"
Old Jun 28, 2012 | 07:50 AM
jephhh's Avatar
Default Rear Wheels "Wobble"
Hello S2Ki,
I was notified by a passerby that my rear wheels "wobble and bounce". Since I got my tires mounted onto the wheels from a powdercoat shop, I was assuming that the tires weren't balanced because the shop guys mentioned they had a difficult time mounting them onto the wheels. But after researching (and by "research" i mean google) further I read it can also be a bent axle, bent rim, conflicting wheel sizes, etc. I just wanted to know if anyone has experience this problem before and any insight would be appreciated.
Here are my wheel/tire sizes:
17x8 +38
245/40/17
Also, lowered on KGMM Springs for a ± 1.5"
Old Jun 28, 2012 | 08:13 AM
daktruckie99's Avatar
Usually when it looks like a tire wobbles or bounces it's just different shades of color playing tricks on your eyes. I see it all the time on truck tires that have a spot of mud on the sidewall. Can you better describe what they actually told you? The other symptom could be a blown shock absorber, in which case the wheel will bounce and you'll see tire tread damage (cupping).
An out of balance tire will be felt when driving, but I can't be so sure as to say that you'd see anything with your eyes on a passing car.
That's my .02.
-Mike
Old Jun 28, 2012 | 08:28 AM
jephhh's Avatar
That's my .02.
-Mike
Mike,
Thanks for your input. I'm familiar with the spots of mud on the sidewall, but this was after a wash and it's been dry for weeks. Unfortunatly, that's all the passerby said and I was planning to get a mechanic buddy of mine to trail me as I drive. But now that I'm aware that my tires wobbling, I now notice it. Not sure if it's just a placebo affect since I was told, but I may have disregarded it because with these springs you feel every tiny bump in the road.
Old Jun 28, 2012 | 08:34 AM
Having someone you trust watch you drive sounds like a good idea.
Good luck.
-Mike
Old Jun 28, 2012 | 12:31 PM
Manga_Spawn's Avatar
Site Moderator
Or let someone drive it and not mention it and see if they feel it. Like others have said you should feel it at least at certain speeds. I would take the car to a tire shop and have them balance them. If that doesn't fix it then look for bigger things. Also sounds dumb but just take the wheel off and put it back on and re torque the lugs. If they are alittle loose it could make it wobble some.
Old Jun 28, 2012 | 01:22 PM
calebzimm's Avatar
if you have coilovers and they aren't preloaded correctly it will do this...ask me how I know.
Old Jun 28, 2012 | 01:25 PM
FluKy15's Avatar
How do you know?
Just kidding
Old Jun 28, 2012 | 03:20 PM
CKit's Avatar
Can you shake the wheel by hand?
Check lug nut torque and axle nuts first.
Any grinding noise like a wheel bearing?
Old Jun 29, 2012 | 08:51 AM
jephhh's Avatar
Originally Posted by FluKy15
How do you know?
Just kidding
lol!
Thanks for all the suggestions!
CKit, no grinding noises from the bearings, but I'll check out the lug nut torque and axle nuts when I get a chance. Thanks!
FISH22
Feb 18, 2011 02:39 PM
vbb
Oct 2, 2008 11:39 PM
shakes
Jan 16, 2006 04:13 PM
gfacter
Nov 15, 2003 09:26 AM
01s2k
Jan 17, 2002 02:15 PM
