Regamaster Marquis Promada 17x8 +25 225/45/17
I have been running as many searches as I can think of for fitment.
I have Regamaster Marquis Promada fronts at 17x8 +25 offset.
I have Star Spec V2 mounted to them at 225/45/17.
The fenders will be getting rolled this weekend. What sort of fitment issues am I looking at for up front?
If a 8" +45 sits flush in the front then that means +25 will stick out 20mm from a stock fender. That's nearly an inch of poke to give you an idea of what's going on. A roll alone won't help. A good pull is going to be needed and also the star specs run wide.
Put them on and see how bad it is. I would go with a 215 so you don't have to do as much fender work. It'll definitely rub if you're not PULLING. So to answer your question, it depends on how much camber. Just put them on, it'll take you 25minutes and a better idea than what we'll tell you on the forum.
Corey Maurer
05-14-2010 09:48 PM
