Rim Size?
How wide can i go with rims on my S2000. (without rubbing) i am getting 18inch rims, just dono how wide to go on rim size. 8......8.5......9.........9.5. Thx thx. Leme know both front and back.
check out this sticky:
https://www.s2ki.com/forums/index.php?showtopic=342793
also, you're in the same boat that I am. You also want to make sure that you keep in mind that tire size plays a big factor in whether or not you rub.
you could fit 18x8 and 18x9.5, you just need to go with crazy offsets, something like +54 in front and +59 in rear
also, if you're planning on lowering the car, or if it is already, that will play a big factor in it too.
if you want to be safe, i'd stick with 18x7.5 and 18x9 rear.... i am speaking about the AP2, if you are AP1, then you want a 1" offset, not a 1.5".
good luck!
good luck!
