stagger and handling question
Old Jan 11, 2006 | 06:53 PM
SojuSoulja's Avatar
Default stagger and handling question
would the handling change for the worse if I were to get 17x7.5 front and 17x8.0 for the rear. I know that the stock stagger is 1" but can I got with a .5" stagger with the right tire size and still not lose any handling?
Would 215 for the front and 245 for the rear be acceptable and would that width fit the rims that I mentioned?
Old Jan 12, 2006 | 04:45 AM
spa-zz's Avatar
An 8" wheel is the minimum width for most 245 mm wide tires, but you can do it. You will lose some of the benefit of that wide tire by putting it on a narrow wheel but it's within the tire manufacturer's recommendations, so you should be fine. The front should be fine as well. Just pay attention to offsets when you choose your wheels. There is a Wheel Fitment Guide sticky at the top of the forum page which will help, if you haven't already read it.
Cheers.
S2KB00ST
Jul 20, 2006 12:31 PM
RogerHinga
Jun 19, 2006 08:27 PM
RIO_Speed
Mar 17, 2004 02:55 PM
Zach H
Feb 10, 2004 11:37 AM
n1kon
Jul 22, 2002 11:03 AM
