rim size question?
Old Oct 6, 2005 | 01:57 PM
SuzukaSauce04's Avatar
Default rim size question?
Would a 18x8 with a 44 offset all around work on a AP2? What is the ideal offsett and width for a 18's???
Old Oct 6, 2005 | 02:17 PM
xviper's Avatar
We have a wheel/tire forum. This is nowhere near a topic for Technical.
They'll stick out a bit. You should also get staggered rims for staggered tires.
"Ideal" offsets for any diameter wheel should be no different than for OEM wheels. It's the tire aspect ratio that must change to make it all work.
OEM 17" rims are 7.5" wide in front with about 55mm offset. 8.5" wide in rear with about 65mm offset.
Old Oct 7, 2005 | 02:12 PM
Slows2k's Avatar
Moving to Wheel/Tire forum
Old Oct 8, 2005 | 12:33 PM
Jim@tirerack's Avatar
Former Sponsor
If you are going to run the same wheel all the way around I think 18X8 and 44mm offset will be a problem. You would need to stay on the narrow side of tires and probably roll the fender lips.
eisenfaust
Jul 7, 2007 01:26 PM
UpTheMileage
Jun 19, 2006 04:54 PM
darkfx
Feb 13, 2006 06:34 PM
05AP2
Jan 26, 2006 07:48 PM
Rdriver
Apr 5, 2002 05:03 AM
