Which rims for J's Racing BBK
Old Jan 5, 2010 | 06:08 PM
hahasti's Avatar
Originally Posted by vtecmall,Jan 5 2010, 11:10 AM
What do you think about advan RG2 in 17x7.5+45 fronts and 17x8.5+50 rears???
Thanks to all of you
with that set up, u dont need any fender mod even if ur slammed.
im not sure about brake clearance though
Old Jan 5, 2010 | 08:36 PM
red@9k's Avatar
GTMotoring had 17x9 +40 RE30s front and rear with the J's Racing BBK.
Front fenders will require a flare and rear will require a roll. Tire size used were 245/40/17 RE01-R but I would personally use a 255/40/17.
Old Jan 6, 2010 | 10:51 AM
rob.ok's Avatar
I do not think they will clear but I doubt anyone has done the calculations or test fitted them. If I remember correctly the 17x9 +45 clears or needs a small 3mm spacer. I pretty sure that is what the original C-West car was running. Again though it needs fender mods but its rather easy to do.
A word of advice....if you are going to be using these brakes on the track I would suggest using a 9 inch wheel up front. With a 225 tire you will not get any benefit over the OEM brakes other than the quick pad changes.
-Rob
Old Jan 6, 2010 | 12:05 PM
vtecmall's Avatar
Thanks for your answer Rob.
So one question, actually I've got this rims (but I still have not checked on the car) Work Emotion Cai en 18X8,5 +42 y 18x9,5 +38 with R888 front 235/40 and R888 Rear 265/35v(if finally I set up this rims, rear I'll put 255/35).
What dou you think about using those rims and wheels?. Advantages or inconvenients from your point of view.
Thanks.
Old Jan 6, 2010 | 12:11 PM
rob.ok's Avatar
No idea without knowing the offset. I would go a head and do a test fitting and see how much clearance you have should take just an hour. Generally you can always use a spacer if there isn't enough clearance. If you need more than 3mm though you will and should change the studs to extended studs.
-Rob
Old Jan 6, 2010 | 12:42 PM
vtecmall's Avatar
-Rob
So sorry Rob, post updated with offset.
With these rims (Work Emotion) the J's racing fits without spacers, my concern is about the performance of the car.
Old Jan 7, 2010 | 08:48 AM
leo520's Avatar
Work Emotion Cr kai en 18X8,5 +42
i have the same wheels..
i measure the wheels with the spoon caliper , and it still have plenties of clearens so i think it will fit...
Old Jan 7, 2010 | 09:32 AM
vtecmall's Avatar
Yes, yes I know that these rims fits, but my concern it's about the performance of the car with those huge wheels (235 and 255).
Several people is telling me that the perfomance whith these Work rims is going to be bad and besides of this I have to roll my fenders, so, because of this I'm wondering to change to 17".
So Leo, how it's your car with these rims?.
Thanks
Old Jan 7, 2010 | 10:34 AM
leo520's Avatar
Thanks
take a look at the pictures..
as for performance, i am kinda like it, i feel more agresive at corners,but diff more stability on high speed..
getting more driver feeling,also a little stiffer than the 17 wheels.
i am running
235/35
265/35
OEM alignment.
but u need serious pulled at the the rear.
Old Jan 7, 2010 | 12:06 PM
vtecmall's Avatar
Great pictures Leo, fantastic car.
Is it your car "turbed"?.
I guees that with those rims my car is going to experiment a lot of lack of performance (mines N/A)
