Rota rims w/ staggard fitment
Old 06-06-2005, 01:29 PM
omgvtec's Avatar
Originally Posted by specialque,Jun 6 2005, 12:37 PM
I think you are looking at the 17" version...which they also have an app for the S2k.
When I look at the 17x8.5" slipstreams, I only see it being available in a 48mm offset? Isn't that too low of an offset for an 8.5" wide rear wheel.
Old 06-06-2005, 02:55 PM
jimmied's Avatar
looks like you can also get the boost(ssr comp), torque(emotion) and rev wheels in 17x7/17x8. both look nice
Old 06-06-2005, 03:58 PM
omgvtec's Avatar
The Torque (Emotion copy) is by far one of the best copy wheels I have seen to date, it's nearly identical looking.
I wish they offered the SDR (NSX copy) in a staggared fittment. It's sick!!
Old 06-06-2005, 05:43 PM
PilotKD's Avatar
I believe +48 on a 8.5" is borderline. They may stick out slightly, but probably wouldn't look too bad.
Old 06-06-2005, 06:07 PM
downhil's Avatar
question for the offset gurus...
will the torque's fit? 17x8 +48 with a 245/35 es100 (or similar) and 17x7.5 +48 with 225's. i plan on going with a medium drop. and wouldn't want to roll the fenders. any thoughts?
even the circuit 10's are staggered now. doesn't look like the front will fit though. 17x7.5 +45 and 17x7 +38
Old 06-07-2005, 09:24 AM
l8brakr's Avatar
I've got the 17x7.5" +48 with 225's and they have only rubbed once when I did an auto-x on my street tires. I have H&R springs that drop .75" in front.
Old 06-07-2005, 09:28 AM
specialque's Avatar
The Torque's will fit.
As for the circuit 10s, they will fit as well. I run 17x7.5 +40 and I don't rub and i'm lowered on KW Variant 3s which are dropped about 1.25in in the front.
Old 06-07-2005, 09:29 AM
specialque's Avatar
+48 will be fine.
The 18" CE's are 18x8.5 +47 in the rear and they fit the car. You'll be fine.
Old 06-07-2005, 09:34 AM
l8brakr's Avatar
And the effective offset on the circuit 10 fronts are only .65mm different than the rears (outside edge) and 3.65mm different than the torques 7.5" +48.
Old 06-07-2005, 10:12 AM
downhil's Avatar
so the torques will fit with those tires i mentioned....good to know.
would the narrower c10 work or would it be better to run the 17x7.5 +45, and simply stagger the tires.
one last question, what is the hub bore diameter needed? there are 2 listed on the jlb site. thanks for all the info! for some reason i just cant get the math of wheels.
Quick Reply: Rota rims w/ staggard fitment
