Rota Slipstream
Old Feb 28, 2007 | 09:03 PM
JerryX's Avatar
Default Rota Slipstream
I'm thinking about purchasing a set of Rota Slipstream. Here are the specs.
16x7 5x114.3 +45mm offset
16x8 5x114.3 +48mm offset
Can I run my stock tires with these (I have 02 wheels). I'm also lowered on Espelir Springs. I know that Rotas are knockoffs but can anybody here tell me your inputs on Rotas.
Old Feb 28, 2007 | 09:06 PM
silentdancer's Avatar
yes those will fit and u can use your OEM tires, im not sure if the hub bore is correct though... anyone else can chime in on that?
my opinion on rotas - you would never see me with rotas on my car.
Old Mar 1, 2007 | 07:50 AM
CobraTi's Avatar
I see no problems with Rota's. Not everyone can afford to spend $2000+ on wheels.
Why go with 16's? I dont think the 17" Slipstreams would cost much more and you'd have more options with tires I believe.
Old Mar 1, 2007 | 08:25 AM
bigmass's Avatar
i just put that exact same set-up on my car. Looks amazing and the wheels are great value. Would buy again for sure. The car will be tracked a lot this summer and these wheels are very very nice for that purpose. Wrapped in Hankook RS-2 it's an amazing set-up
As for why not get 17"? because Rota made a great 16" wheel that is lightweight, however their 17" weighs 5-6lbs more. The 17" Slipstream is just for looks while the 16" has practicality.
Old Mar 1, 2007 | 09:27 AM
Xistence's Avatar
You just need to check the hub bore.
I would order from Machiii.net. Great service and they will make sure the hub bore is correct for you and include the hub rings, since they will be necessary for the front wheels (pretty sure it's the front wheels, but either way, they'll be need for the wheels with the smaller hub bore).
Old Mar 1, 2007 | 01:13 PM
colatkitty's Avatar
I'm thinking about going with the same 16" set-up as track wheels. I know that using the stock S02's will be OK, but does anyone know if I can squeeze in 225/50 fronts and 245 or 265/45 rears R-comp without rubbing?
Old Mar 1, 2007 | 02:15 PM
common reactor's Avatar
I also started a thread on Rotas a while ago, and honestly after thinking about it, I wouldn't do it. The slipstreams look great and they're cheap, but I would feel very uneasy about having them on my car.
Old Mar 1, 2007 | 06:48 PM
kchandra's Avatar
JerryX - what tires do you plan on running with that setup? I was looking into the same thing as well. My concern is the fact that I want wider than stock tires.
Old Mar 1, 2007 | 07:08 PM
ericshun's Avatar
for the 16" theres all the rubber i'm not really too scared about that
Old Mar 17, 2007 | 03:53 PM
txs2knoah's Avatar
so if i want to order slip streams in size 17.. whats mm offset should i be safe with .... in the front and the rear wheels ?
dsddcd
Mar 24, 2010 08:31 PM
Dr Jekyll
Aug 11, 2007 07:46 AM
ernisill
Feb 5, 2007 12:33 PM
shadykit
Jan 21, 2006 05:17 PM
waterhound7
Nov 29, 2002 10:42 PM
