Rpf1 BBK Fitment
Originally Posted by FRSKLLR' timestamp='1463435133' post='23968399
[quote name='s2000Junky' timestamp='1463434472' post='23968387']
You would want the 8.5 +40 option to fit. The 8 + 45 option is a bit less aggressive for fender fitment and may also fit, but you would want to double check on that spec. For sure the 8.5 +40 will.
[/quote]
I thought downforce are 30mm? Wouldn't that be plenty if I added a decent amount of camber. And yeah I just have someone offering me a fair amount for the stock fenders so I rather just get wider fenders
Originally Posted by s2000Junky' timestamp='1463436392' post='23968415
[quote name='FRSKLLR' timestamp='1463435133' post='23968399']
[/quote]
[/quote]
Correct, my mistake. Still wont fit with an effective 9 +25 offset. Your going to need J's fenders or something else that is 40mm wider then stock. Then you have to figure out what your going to do for the rear so your not increasing the front track width 80mm alone. Or you could just get a convex wheel with a proper offset. Or shop for an expensive custom offset multi piece wheel.
Your best bet is to buy a different set of wheels. I am fairly sure that there are options in the 17x9 +45 size that also fit BBK's. Hell my 5Zigen FN01r-C's in 17x9 +43 fit over my brembo's and would fit over stoptechs as well. Sell your RPF1's as a set and look for different wheels.
Let's see they have the same face so no they won't. You have already rejected the style of rpf1 that has bbk fitment. So either A buy new wheels or B spend thousands on body parts, paint, cut up your car, run stupid spacers, and stay with the same wheel or C don't buy a BBK. Selling a set of 17x9 +45 rpf1's should be pretty easy so long as they aren't damaged or in otherwise bad shape. Look through the stop tech thread and find a wheel with similar or the same specs and buy those.
Well that sucks! I was just thinking that next years tax refund would go towards BBK, but I used this years tax refund on the RPF1's. The only other wheel I would consider are the Advan RG-D's. Will those work with BBK?
Why don't you do some research before buying parts?
https://www.s2ki.com/s2000/topic/771...itment-thread/
Go through that thread.
