RPF1's
im looking on the website for the wheels..i priced everything and it was like 1400 something..with tires. so i think im gonna do it...is there a special discount code for s2ki members? someone mentioned something and i was just curious..and second question is for the rear tires..it had a recommened fitment for the tires at 245...would i be safe with a 255? i would imagine i have a little room to play with cuase its only a 8 inch wheel? thanks in advace
Originally Posted by silentdancer,Feb 22 2007, 09:22 PM
if you check with evasive.. they have 17x8,17x9+45 all around. if you want a more "flush" look.
http://www.evasivemotorsports.com/merchant...Code=ENKEI-RPF1
I love these wheels. Hopefully there is a good offset/width for the front. I don't really want 7.5 +48 in the front because the spokes stick out almost flush with the lip.
Is there a way on the tire rack site to look at what size/widths/offsets are available for each wheel?
Or check the Enkei site: http://www.enkei.co.jp/en/p_detail_rpf1_pri.html
They're not expensive wheels. $240-250 each is around average. And under $100/tire is doable if you're not expecting the best tires in the world. Sumitomo HTR Z II's go for $70-80/tire in 17" S2000 sizes, and they'd probably outperform some of the suggestions I've seen thrown around on here.
it'll stretch the sidewalls... x8.5 should be fine
