RPF1's
Old Feb 22, 2007 | 11:38 AM
AkA S2K's Avatar
Default RPF1's
im looking on the website for the wheels..i priced everything and it was like 1400 something..with tires. so i think im gonna do it...is there a special discount code for s2ki members? someone mentioned something and i was just curious..and second question is for the rear tires..it had a recommened fitment for the tires at 245...would i be safe with a 255? i would imagine i have a little room to play with cuase its only a 8 inch wheel? thanks in advace
Old Feb 22, 2007 | 12:02 PM
AP2's Avatar
AP2
i think a 255 on an 8 is a little too much, i would just stick to the 245...
Old Feb 22, 2007 | 07:31 PM
s20oo's Avatar
it'll stretch the sidewalls... x8.5 should be fine
Old Feb 22, 2007 | 08:22 PM
silentdancer's Avatar
if you check with evasive.. they have 17x8,17x9+45 all around. if you want a more "flush" look.
Old Feb 23, 2007 | 12:11 AM
vtechnique's Avatar
hmmm... i actually couldnt find +45 offsets for the 17x8 and 17x9... do you have to call them for a special order?
http://www.evasivemotorsports.com/merchant...Code=ENKEI-RPF1
Old Feb 25, 2007 | 09:31 PM
SimpleMan's Avatar
I love these wheels. Hopefully there is a good offset/width for the front. I don't really want 7.5 +48 in the front because the spokes stick out almost flush with the lip.
Is there a way on the tire rack site to look at what size/widths/offsets are available for each wheel?
Old Feb 26, 2007 | 04:52 AM
stealthx32's Avatar
No. Its a liability thing, mostly. Just call and ask if you're curious.
Or check the Enkei site: http://www.enkei.co.jp/en/p_detail_rpf1_pri.html
Old Feb 26, 2007 | 12:28 PM
yms2k's Avatar
I was going to order a set from a local wheel shop, 17X7.5+48(f), 17X9+45
Old Feb 26, 2007 | 05:23 PM
JDM S2000's Avatar
Banned
1400 for those rims and tires, id like to see that.
Old Feb 26, 2007 | 05:28 PM
stealthx32's Avatar
They're not expensive wheels. $240-250 each is around average. And under $100/tire is doable if you're not expecting the best tires in the world. Sumitomo HTR Z II's go for $70-80/tire in 17" S2000 sizes, and they'd probably outperform some of the suggestions I've seen thrown around on here.
