Rubbing with 17" RG II
I just had my new wheels put on today and am rubbing. Here is my setup: 17X7.5 +45 with 225/45/17 Advan Neova and 17 X 8.5 +50 with 245/40/17 Neova. I am lowered 1" on Swift springs with Koni yellows on the stock perch. Will the UK/Euro alignment specs fix my rubbing problem? I thought this was a fairly safe setup and was surprised to hear the rubbing on freeway bumps.
thanks for any help
thanks for any help
i basically have the same set up but with 255/40/17 in the rear. I would say you need to roll your rear fenders. I have the UK alignment specs and still rubbed, had to roll my rear fenders. I am lowered on pss9 which is probably similar to your set up. you "should" be fine in the rears after that, i just dont know your spring rates
BTW i still rub on hard turns in the front (i have 225/45/17 but my offset is 48).
hopefully that helps
thanks for the advice. I was surprised, but realize that the Neovas run wide for the stated size and the 225 front with a +45 was going to be tough to totally eliminate rubbing. I replaced my Advans with Eagle F1 GS03s in 215/45 245/40 and no more rubbing.
Originally Posted by duff0000,Apr 24 2007, 10:51 PM
I hear if you roll your fenders it will be fine, this is with 17x8.5 50 and 17x9 45 in the rears.
Originally Posted by cusco,Apr 26 2007, 11:15 AM
Yeap... jcurtis is running that with 225's on the front and 255's on the rear. He says only under hard braking does his fronts rub and he is much lower than a 1" drop. He is running the U.S. alignment specs.
orangebarius
39
Mar 9, 2009 05:39 AM
