rubbing
Old Jan 10, 2008 | 11:00 AM
kpxtweeks's Avatar
Default rubbing
im on 17x8 +50 offset in the rear and my fenders are rolled and im dropped on espelir springs. problem is im running 255 r615 and will rub on big highway inperfections. Camber is at -2.7 and still rubbing. Please help
Old Jan 10, 2008 | 11:10 AM
Jim@tirerack's Avatar
Former Sponsor
What is the size on the tires?
Old Jan 10, 2008 | 11:13 AM
AP2's Avatar
AP2
hm..that sounds weird. with that setup you should clear, it may be caused by the tire being too big for the wheel. it might bluge a little which is causing the rubbing.
Old Jan 10, 2008 | 12:25 PM
S2K1985's Avatar
you need to relocate your bumper screws..I helped one of the fellow s2ki member relocate his since he was having the same problem..he was running w/ a spacer and a -30 offset at the back..just move the screws back about 1 1/2 inch...need to drill out a new hole of course..and cut out the old screw hole..that would solve your problem..oh and if your wondering about is camber his running guessing -3 or more..GL man..hope to hear an update soon..
Old Jan 11, 2008 | 09:02 AM
kpxtweeks's Avatar
tire size in the rear is 255/40/17. Would putting on 245's help it? I tried to see about the tab but theres barely any room to drill a new hole towards the rear of the car about an inch to 2 inches from where its at. Help?
Old Jan 11, 2008 | 09:07 AM
S2K1985's Avatar
ill take a picture of it then post it here so you can see how its done...i did it very professionally..
Old Jan 11, 2008 | 09:11 AM
kpxtweeks's Avatar
sounds good
RagingCheese
Dec 31, 2015 04:08 AM
SUBLIMEAE86
Jul 21, 2015 09:29 AM
Silvers2kdaily
Jul 19, 2015 05:47 AM
ktpp35
Mar 1, 2013 07:31 PM
SUBDRE
Mar 14, 2006 01:29 PM
