View Poll Results: Which is the better tire for the money?
Voters: 26. You may not vote on this poll
S-03 or RE050
S-03 or RE050
I'm in the market for new tires and there is a special on tire rack right now for approx. 100 bucks off for these tires, and I'm curious for your guys' input.
thanks a lot,
Josh
thanks a lot,
Josh
I'm thinking about going to SO3s when my OEMs need replacing.
The front SO3's (stock 17") have 1.3 inches greater tread width than the RE050s. The rears have the same tread width as RE050s. This changes the stagger significantly.
Anyone running the SO3s care to comment?
the real question is what are the correct sizes for replacing our stock s02's? I have another thread that's been trying to answer this question and it seems we have hit a crossroads. We need to find out that if by increasing our tire size to match the contact patch of the s02's are we actually decreasing it due to the crown effect that apparently happens due to the tire bieng too wide for the rim?
The issue on the RE050's is the narrow fronts.
thanks
Originally Posted by RED04S2k,Apr 13 2005, 09:59 AM
I'm not sure what you mean by what you're saying. The fronts of the S-03s will have more rubber touching the ground than the RE050s? If so is that a problem?
thanks
thanks
The car suspension was designed around the RE050's. Using S03's could change the behavior of the car by significantly reducing understeer. That's why I am trying to get input from people with 04/05 models that have changed from RE050's to S03's.
