S02's Discontinued!?...Is this True!
Old Mar 7, 2002 | 08:07 AM
enzyme's Avatar
Default S02's Discontinued!?...Is this True!
I went into my local Firestone and My Manager friend says that Bridgestone S02's are being discontinued. I need conformation from another source, because if it's true I'll just have to buy the LOT!
Old Mar 7, 2002 | 11:24 AM
Phantom's Avatar
I hope he is confusing the fact that the S02 (Pole Positions) are being discontinued.
Old Mar 7, 2002 | 11:57 AM
Jim@tirerack's Avatar
Former Sponsor
No they are not discontinued. The S02 Pole Position is discontiued. Call me if you need the tires.
Thank you
Jim 800-428-8355-364
Old Mar 15, 2002 | 08:13 PM
S2Krazy's Avatar
What is the difference between standard and pole position? In the Tirerack catalog they look identical.
Old Mar 15, 2002 | 09:26 PM
bayarea408's Avatar
[QUOTE]Originally posted by S2Krazy
[B]What is the difference between standard and pole position?
Old Mar 16, 2002 | 05:00 AM
Former Sponsor
The difference is in the rubber compound. The Pole Position is a dual layered rubber compound that will give better and extended wet performance. They also made the OE tires wider than normal rear and narrower than normal front.
I am sure there are other differences but there are a secret between Bridgestone and Honda.
Jim
Old Mar 16, 2002 | 06:47 AM
S2Krazy's Avatar
So our stock tires are not pole position, right?
Old Mar 16, 2002 | 08:21 AM
Kwando's Avatar
Correct!
Old Mar 18, 2002 | 03:27 PM
Zangerzone's Avatar
I wouldn't order from any Firestone dealer because of their high markups. I just had my tires replace on the rears. I figured that Firestone would be the best place to start since they do make the tires. They quoted me $265 per tire! I asked them if they would match TireRacks price. They said no because they are not a dealer that installs tires. Then I asked if they would with Discount Tires. Discount Tires wanted $179 per tire which is alot more reasonable and pretty close to Tire Racks price. They again said no because they are a "dot-com" store. I was like whatever and left. I am really suprised Firestone dealers can even stay in business with the way the responded to my question. Never again!
Tire Rack rules!
Jeffrey
SstoneS2k01
Mar 3, 2004 07:03 PM
Ajjra
Nov 19, 2003 05:00 PM
WhiteS2k
Oct 31, 2002 10:08 AM
collin228
May 23, 2002 09:54 AM
Fito
Nov 2, 2000 02:43 PM
