size of spacers calculation needed
Old May 21, 2005 | 10:53 AM
Xplosiv's Avatar
Default size of spacers calculation needed
I want to run Spoon Calipers with MF10's, I was wondering how much the spacers I need to clear them.
MF10 F: 17 x 7.5 with 52 offset
I dont mind the JDM flash fender look.
Thanks in advance!
Old May 21, 2005 | 12:06 PM
Jim@tirerack's Avatar
Former Sponsor
You would not have to run a spacer with the 52mm offset. I just would not recommend to run the same wheel on all four corners on the S2K.
Old May 21, 2005 | 12:56 PM
Xplosiv's Avatar
Jim, I am confident I need some spacers to clear the Spoon calipers. I just dont know what size of spacers I should run.
Old May 22, 2005 | 07:03 AM
SIIK2NR's Avatar
Here's some info I dug up that JsAP1 provided.
"You can actually run 16, 17, or 18 inch wheels. It all depends on offset, spoke curvature, and size. You can get away with a few 17 inch wheels with no spacers. I know for a fact the following fit with Spoon calipers."
Weds Sports SA90 +43 front
Black Racing Pro N1 +45 front
SW388 +35 front
Work Emotion CR 17 +43 front
Work S1 3 piece +37 front
Prodrive NSX look a like wheel +43 front
Based on your offsets you will probably need 8-10mm spacer which is going to require extended lugs. Hope this at least gets you in the right direction.
Old May 23, 2005 | 02:04 PM
ASMspec's Avatar
I believe Dickson (DCAP1) had this setup up. I think you could get away with a 10mm spacer but for some reason I want to say he told me he had two spacers so a 15mm on each side with extended studs.
Old May 23, 2005 | 02:09 PM
Xplosiv's Avatar
Thanks Chris.
jvr
Oct 28, 2009 09:00 AM
jvr
Jul 23, 2009 04:53 PM
irev9k
Oct 14, 2008 09:40 PM
mr_grand_prix
May 2, 2008 02:23 PM
Mr. Francesco
Jan 16, 2007 10:28 AM
