SO3 225's on the rear
Old Dec 17, 2003 | 08:07 PM
hyperpm's Avatar
Originally posted by suzukablueS2000
well.. my rear oem tires had weared out.. and the fronts are still in a very good condition.. when i wanted to change the rears for new so2s i found that our dealer doesnt bring them right now.. so can i use s03s in the rear (245/45) while keeping the so2s in the front or should i change the four tires!!
change all four.
Old Dec 17, 2003 | 09:24 PM
MeCCaJM's Avatar
[QUOTE]Originally posted by hyperpm
Old Dec 18, 2003 | 03:54 AM
BEC71's Avatar
I've been running different rears than the fronts for the last 10,000 miles with no problems. While I agree it's best to have 4 matched tires, for daily driving, it won't kill ya to put on different rears.
Old Dec 18, 2003 | 12:17 PM
suzukablueS2000's Avatar
i guess im going to change the four tires then
Old Dec 19, 2003 | 05:26 AM
Tedow's Avatar
It is not necessary to change all 4 tires. I've been running on "mis-matched" front-rear tires for close to 20000 miles now with no problems. One of the non-OEM sets of rear tires I had were 245/45 SO-3's. There was very little noticeable difference in the balance of the car. However, with 225's I imagine it'd be scary...the OEM rear tires were even wider than the 245's I had. I'll note that while the SO-3's did have much better hydroplane resistance than the stock tires, they wore out even faster.
Anyway, the short answer is that if your tire selection is right, you won't have any problems running different tires on the front and rear, so there's no point in throwing away two perfectly good front tires.
Old Dec 19, 2003 | 11:18 AM
thank u very much Tedow for clearing the point i guess ill take your advice
Old Dec 21, 2003 | 06:44 AM
sparky57's Avatar
Originally posted by FLS2K
The oversteer potential was so bad I had to run the tires a few pounds lower to TRY and compensate.
That was your second mistake. You should have increased tire pressure in the rear or reduce the fronts to minimize oversteer.
rw
Old Dec 22, 2003 | 05:20 AM
BEC71's Avatar
I snapped a couple pics of 245/45/16 SO3's and 225/50/16 SO3's.
http://f2.pg.photos.yahoo.com/ph/justdigit...igits/my_photos
boltonblue
May 15, 2016 05:05 PM
jhrowney
Jan 7, 2005 08:41 AM
alex s
Sep 23, 2004 11:13 PM
Al Wilson
Aug 18, 2002 05:27 AM
JT-KGY
Feb 20, 2002 11:08 AM
