Something wrong with car
Old Nov 27, 2006 | 02:03 PM
King_'s Avatar
Default Something wrong with car
Hey everyone,
I had new tires put on my car two days ago. Ever since then it feels like I"m driving a boat. The rear end is completely loose. Whenever I hit a bump it feels like i'm going to loose control, at high speeds my whole car feels like it's going to take off like an air plane, extremely wobbly. . I checked the rotation on the tires and they are all going the same direction. I replaced my old tires with the exact same new ones. Potenza RE050's
I have an 06 w/16000 miles.
Old Nov 27, 2006 | 02:12 PM
raymo19's Avatar
I know this is going to sound like a Christmas Chestnut but:
Have you checked the tire pressures? And the torque on the lug nuts? And how did they balance the wheels?
Old Nov 27, 2006 | 02:28 PM
King_'s Avatar
I checked the torque, and they balanced the wheels on a balancer that does the road test. . if that makes any sense.
Old Nov 27, 2006 | 09:14 PM
djpeak10's Avatar
Same thing happened to me and I checked the tire pressure and one was at 40 psi and one was at 35 so I put them both at 34 psi and problem was gone.
Seriously I had that same exact feeling.
Old Nov 28, 2006 | 02:47 AM
King_'s Avatar
THANKS! I'll check that first thing today!
Old Nov 28, 2006 | 09:02 AM
Drkphnx's Avatar
You may want to have them recheck the balancing, i had the same problem. i had them rebalanced and the shaking is gone. dont drive to fast, i lost control at 75.
Old Nov 28, 2006 | 11:17 AM
CaptainMike's Avatar
This may sound like an extra stupid question, but please understand we get all kinds on here, you didn't buy rears same as the fronts did you? they should be 245/40's , other issues already mentioned, uneven tire pressures, poor balancing, the release compound can also make some tires really squirrely for the first 150 miles or so though I have not noticed this too much with RE050's.
Old Nov 28, 2006 | 11:30 AM
CosmosMpower's Avatar
Make sure the rears are in fact the wider rear wheels. A local guy got new tires at a shop here and felt a wobbling on the highway. We stopped to check it out and the shop had mounted the 245 rear tire on the front 6.5" wheel and put it at the back. The front offsets DEFINETELY do not fit on the rear.
Old Nov 28, 2006 | 01:10 PM
enrique_s2k's Avatar
that seems to happen alot that is going on with my car and if you know what to put on a 17X7 rim with a offset of 42 let me know
Old Nov 29, 2006 | 02:31 PM
King_'s Avatar
I just wanted to say Thank You to everyone! I checked the tire pressure this morning and it seems that someone put 50lbs. of pressure in each rear tire so after bring them back down to 34lbs. Everything seems to be okay again!
Thanks for all the help!
