Squirrelly Rear end
Old Aug 17, 2002 | 08:03 AM
jebario's Avatar
Default Squirrelly Rear end
Ok, so I needed new rear rubber and decided to go with another brand. Bad idea . I went with the right size 225/50R/16 92W, but tried Falken and then Yokohama. Both sets for rear tires made the rear end of the car act squirrely. It has a mind of its own. it tracks differently than the front and seems to "oversteer" ( probably wrong term for rear end ) in turns. I have the S-02s on order and wonder will this fix the problem or is there something bigger going on?
Old Aug 17, 2002 | 02:03 PM
RT's Avatar
RT
Originally posted by jebario
I went with the right size 225/50R/16 92W, ...................
see thread titled NOTICE: Correct Rear Tire Size
Old Aug 19, 2002 | 07:42 AM
Jim@tirerack's Avatar
Former Sponsor
You should have called me. In an aftermarket tire the better size would have been 245/45R16. You can also have the probelem you are mentioning by mixing the tires. The 225/50R16 aftermarket tires are about 2/3" narrower than the OE rear tire. This will create oversteer.
Jim 800-428-8355-364
Old Aug 19, 2002 | 01:37 PM
jebario's Avatar
Got the OE tires yesterday and had them installed. All is well again with my rearend.
Thanks for you r help.
krazik
Feb 28, 2010 03:53 AM
JLUDE
Sep 8, 2009 11:13 AM
TurboDSMJ
Nov 17, 2006 09:33 AM
tlegend
May 18, 2006 10:19 AM
pushinlsteg
Apr 4, 2006 02:50 PM
