ssp sp1 17x8.5 +47offset
i found some ssr sp1 specs are 17x8.5 +47 on all fours
what tire size can i put on the front and back and the biggest question is will they rub. the store will close in two hours so i need all the help i can get
thanks you guys
thanks you guys
I'd pass, you won't get the right tire fitment on a proper stagger on those wheels, the offsets are also low, you probably won't rub at stock height with streched front tires, but you probably will if dropped without extreme camber or fender rolling.
