staggered setup on front wheel drive
Old Jul 20, 2010 | 07:24 AM
zeroedout's Avatar
Default staggered setup on front wheel drive
I'm curious. Is there anything bad about have a staggered setup on a front wheel drive car. Lets say you put AP1's on like a civic or an accord. Would the staggered wheel setup hurt the cars stability? Would it even matter? Would the rear's stick out more than the front? I'm just curious.
Old Jul 20, 2010 | 07:26 AM
GateCrasher's Avatar
Your question will receive better answers in the Wheel and Tire Section...
Old Jul 20, 2010 | 07:29 AM
zeroedout's Avatar
Can a mod move it for me?
Old Jul 20, 2010 | 07:39 AM
patinum's Avatar
I've heard some civic racers run wider in front than back. Changing the stagger of any car will effect handling. Driving style and or suspension components should be changed accordingly.
Old Jul 20, 2010 | 08:04 AM
Froth.'s Avatar
If you look at a lot of the FWD Time attack cars in Japan they use a FWD stagger(wider wheels/tires in the front) to improve handling.
-Froth
Old Jul 20, 2010 | 08:09 AM
clarkster009's Avatar
^ Ya as well as the drag cars...so they can get more traction up front for accelerating. Not sure if there would be any performance benefits to other way around but it might look cooler.
Old Jul 20, 2010 | 10:30 AM
orangebarius's Avatar
people put 4 ap1 fronts on civics and integras with the 5 lug conversion. i dont believe ap1 rears will fit unless you bore out the hub.
Old Jul 20, 2010 | 12:09 PM
spdracerut's Avatar
FWD cars come with even width tires from the factory. Almost every single one of them understeers from the factory. If you fit the standard RWD stagger on a FWD car, where the fronts are narrower, it will understeer even worse!
Old Jul 20, 2010 | 01:00 PM
zeroedout's Avatar
So putting AP1 rears on the rear and ap1 fronts on the front could cause more understeer. This is on a 98 honda accord coupe.
Old Jul 20, 2010 | 01:51 PM
mister x's Avatar
Yikes, I thought you were talking about wider on the drive wheels. What you're thinking about is bad for handling. Personally if I had a FWD car I'd run staggered like this FD2, it should help with the understeer.
[media]http://www.youtube.com/watch?v=bUbEh4GVCKc [/media]&feature=related
