Staggered snows or matching set?
Old Nov 30, 2015 | 12:05 PM
vtec9's Avatar
Default Staggered snows or matching set?
Hello,
For many years I ran propely sized staggered snow tires on my '00 (205/55/16, 225/50/16). Due to the lack of available options though, a few years back I went with a 205/55/16, 215/55/16 setup (Michelin xice3). The rear tire was ~1.8% larger than stock.
I need to replace my rears only. Think I should repeat the larger size or just run 205/55s all around? I'm in CT and we get a good amount of snow.
Thanks
Old Dec 3, 2015 | 05:32 AM
vtec9's Avatar
Up
Old Dec 3, 2015 | 09:59 AM
rrounds's Avatar
Your not racing on snow tires so I would go with the taller tires. And just for the hell of it I would see if the taller 215/55-16 snow tire would fit up front without rubbing. That will give you a little more height up front to clear the crap on the road in winter.
I have a '06 and run 235/45-17 up front(stock wheels) and they don't rub on the fenders at all.
ROD
Old Dec 5, 2015 | 01:14 PM
TJE199's Avatar
I agree with trying to see if the taller tires would fit up front as well. I get a ton of snow where I live and I'm always worried about damaging the lip on my bmw in deep snow (never know where that chunk of ice will be) so I went with a slightly taller square setup and haven't had any problems. The extra ride height is nice in winter and doesn't really affect handling to a noticeable point (almost never driving fast enough for that anyway in the snow).
Old Dec 7, 2015 | 06:39 AM
vtec9's Avatar
I went with the 215/55s again in the rear. Not swapping out the front because the current tires have life left. Thanks for chiming in.
Old Dec 9, 2015 | 12:17 PM
rrounds's Avatar
When your front snow tires do wear out see if the 215/55-16 will fit and not rub on the fenders. 215/55-16 is just about 1/10" (or less) shorter than the 235/45-17 tires I run up front on my '06 S and I have never had them rub on the fenders and I take my S on some rough back roads. Most of the roads I drive are back roads, I like the out of the way roads to drive.
ROD
rbtz
Nov 2, 2016 05:17 AM
josh7owens
Nov 10, 2010 08:44 AM
TookayS2K
Aug 30, 2010 05:48 PM
ProV1
Aug 1, 2007 01:20 PM
themadchef
Nov 21, 2003 10:13 PM
