Stock ap1 wheels
Old Jul 4, 2008 | 12:46 AM
clitsy's Avatar
Default Stock ap1 wheels
First off, I've tried to search but the search button doesn't work right on my computer.
I've been considering picking up another set of rear ap1 wheels so i can run 225s all around instead of the staggered setup. I"m assuming the wheels are diff offsets between the front and back. So will rear ap1 wheels with the 225 tires work fine up front without any rubbing issues? thanks
Old Jul 4, 2008 | 04:34 AM
negcamber's Avatar
Rubbing won't be a problem...what is a problem is that the hub diameter is different front and rear. The front hub is larger...you can fit a front wheel on the rear, but a rear won't fit on the front without a machine shop modifying the wheel to increase the hub diameter.
If you really want no stagger...pick up some ap2 rims instead and run 245s all around.
Old Jul 4, 2008 | 07:05 AM
PanteraKitty's Avatar
225 will fit all AP1 wheels. I use 225 front and 245 rear for street and 225 Kumho V710 all around for autocross.
Oombop
Nov 8, 2013 01:28 PM
s2kpotenxixe
Sep 18, 2013 12:47 AM
lucasbrock84
Oct 21, 2012 02:39 PM
86s2k
Jul 10, 2008 03:20 PM
Slideways99
Apr 23, 2007 07:07 AM
