TE37 Fitment Help
Old Mar 7, 2019 | 12:38 PM
S2K Tae's Avatar
Default TE37 Fitment Help
How would the fitment Be running this setup , I don’t want to do any pulling/rolling and if so the minimum amount. Want to have a more aggressive look and I’ll also be lowered about 2 inches from stock heights. Also what tires would I need or could run
x2 17x8.5 +40
x2 17x9.5 +35
5x114.3
Old Mar 7, 2019 | 12:42 PM
TsukubaCody's Avatar
Those won't work. Do way more research.
Old Mar 7, 2019 | 01:14 PM
Chibo's Avatar
Cody is right, that isn't happening. Aggressive look and untouched fenders do not go together, especially dumped two inches.
Old Mar 7, 2019 | 01:45 PM
Colin Shipp's Avatar
x2 17x8.5 +40
x2 17x9.5 +35
5x114.3
you need +60s to fit 9.5 wheels to standard car at standard ride height
Or roll the fenders 25-30mm for your rims
Old Mar 7, 2019 | 04:21 PM
Manga_Spawn's Avatar
Site Moderator
You can't have both no rolling or pulling and an aggressive look. Those sizes are way too aggressive and would require a roll and likely a pull on all 4 corners. Like Colin said you need to be in the +55 or higher (ideally above +60) to not touch the fenders.
Old Mar 7, 2019 | 04:25 PM
S2K Tae's Avatar
I don’t mind rolling and pulling if it’s just minor , just wanted to know was the set up possible without all out destroying my body line .
Old Mar 7, 2019 | 05:07 PM
silhouette's Avatar
https://www.s2ki.com/forums/wheels-t...-guide-342793/
Old Mar 8, 2019 | 09:07 AM
Site Moderator
I mean there isn't really a minimum amount. The fenders are either rolled or the aren't. Pulling there is varing degrees of pull you can have but for those specs its going to need a pretty noticeable pull and how it looks will depend on how good the person you have to do it is.
Old Mar 20, 2019 | 01:54 PM
xxyion's Avatar
Bit late to this party, however im going to be running a square TE37 setup and this will be my specs.
17x9.5 +41 (evasive spec) with 245/40/17 tire
camber: -2.5 all around
drop: 1.5"
I have also gotten my fenders trimmed and rolled (no pull) so I look stock still.
Even with all that this is a very aggressive setup and will probably need some adjusting once everything is on. I suspect I should be able to drive this around with no issues however I am prepared to add more camber and rise my ride height to compensate. I'm also running a slightly thinner tire to account for tucking under my fenders.
I am assuming you want the lower offsets to get that concave look. Try and get the spec from Evasive Motorsports as those are a pretty concave looking setup with a decently high enough offset that it "may" not require a fender pull if you are willing to sacrifice other things (upping ride height, more camber, thinner tire).
Old Mar 20, 2019 | 02:03 PM
S2K Tae's Avatar
drop: 1.5"
that was the original plan , but I’ve talked to the guys at evasive and all the colors I liked are pretty much snagged up for this upcoming batch they ordered
