Tire Rack question
Old May 4, 2007 | 06:00 AM
Suzukaboy's Avatar
Default Tire Rack question
I have been researching tire options and notice that the Overall Diameter quoted doesn't seem to calculate to the RPM numbers. I didn't check them all obviously but for example the 245/40 ZR17 RE050 shows RPM of 847. Yet I calculate 820RPM using the 24.6in OD.
Are your numbers test numbers or is some factor applied to the calculation? I got into this trying to figure out what the odometer errors might be with different tire options.
Thanks
Old May 4, 2007 | 12:54 PM
ZDan's Avatar
Effective LOADED radius is less than half the diameter, that's why the revs/mile are greater than you'd calculate from the OD measurement.
Old May 4, 2007 | 01:34 PM
Suzukaboy's Avatar
I looked back at some of the specs I have and I notice Static Load Radius in the RE050 specs and it is less than 1/2 the diameter. I bet their computer designs give them that number. Thanks for the tip.
friendlydacat
Mar 29, 2009 10:31 PM
Russian
Jun 23, 2004 01:57 AM
negcamber
Jan 6, 2003 02:10 PM
av8tor2
Nov 8, 2001 05:25 PM
