Tire/Rim fitment
Old Dec 17, 2005 | 11:40 PM
Aznous's Avatar
Default Tire/Rim fitment
Quick questions will a 245 width tire fit on a x7.0 rim... Is that pushing it? I also have a set up on my S....225/45/17 Front 245/40/17 Back.... Is that the right series for that set up?
Old Dec 18, 2005 | 05:50 PM
spa-zz's Avatar
245 is technically too wide for a 7" wheel. You can stuff it on there, but you'll get a crowned tread face resulting in uneven wear and less grip. You typically need a 8" to 8.5" wide wheel for a 245 tire. On the AP1 wheels we sometimes use a 245 on the 7.5" wheel and this is already pushing it.
225/45 and 245/40 is fine for 17"... as long as you have a wide enough wheel in the rear.
Old Dec 18, 2005 | 11:34 PM
Aznous's Avatar
Thanks for the comment spa-zz...Well thats what I have it looks pretty flushed Iam supprized that the FIRESTONE recommended these messurements on a 7 width rim....Also the series are correct I guess I thought I would just keep the front 40 and the back 40 series But it makes sense....
Old Dec 19, 2005 | 08:43 AM
spa-zz's Avatar
Don't be surprised. If it can be jammed on there, most tire shops will "recommend" it in order to make a sale. If it'll roll outa there, they'll sell it to you. But the S2000 is a bit of a special animal because of it's requirement for very high wheel offsets as well as a stagger.
I'd keep a close eye on your rear tire wear at least.
Cheers.
Old Dec 20, 2005 | 01:41 AM
Aznous's Avatar
Paying for an alignment does that fix the camber at all? I have a 2 inch drop...
TankWookie
Mar 26, 2015 11:04 PM
whaninoz
Jun 25, 2011 11:35 AM
BanzaiS2K2003
Jun 4, 2010 12:29 PM
Ro_Ja Boy
Dec 20, 2006 03:47 PM
TypeSH
Apr 26, 2002 12:49 PM
