Tire/rims size for lowered ap1 with BBK
Old 02-22-2018, 11:15 AM
S2000_fury's Avatar
Hey guys, let me revise the question a little. I understand wanting a square setup is really limiting my options so let' try this:
Minimum 225 upfront and 255 in the rear. Still want to be able to run the big brake kit (preferably Wilwood).
That should open my options a little more.
After doing some research these last few days I found that the ap2 v3 wheels will be a good contender. I heard that with a 5mm spacer you can clear the Wilwood brakes.
Old 02-24-2018, 01:03 PM
Site Moderator
Manga_Spawn's Avatar
Easy do the enkei RFP1's junky mentioned and call it a day, The 17x8 RPF1's have tons of clearance and wilwood needs the least amount of room.
Old 03-01-2018, 10:25 PM
S2000_fury's Avatar
how wide of tires can you go with those? Would 245/255 be pushing it?
Old 03-02-2018, 08:21 AM
Site Moderator
225 is a better fit on the 8 inhc wide wheels IMO. I guess you could squeeze a 245 on there. It would just be pinched,
Old 03-02-2018, 09:22 AM
DrakeValle's Avatar
I'm running the 8-225/9-255 stagger. I agree that 225 would be the way to go on the 8in wheel. Overall I really like the setup, but as previously stated, I'm not a huge fan of the convex on the 8in RPF1s (especially in SBC).
Old 03-03-2018, 02:40 AM
flanders's Avatar
Which Wilwood bbk would clear these wheels? I haven't found a single kit that fits without some spacers.
Is it this one? Wilwood High Performance Disc Brakes - Front Brake Kit Product Number: 140-10309
Old 03-03-2018, 08:29 AM
eight's Avatar
I ran 17x10 +50 advan RS2's with my ap racing BBK on 255 ad08r squared and it cleared without a problem. That was with a pull on all 4 corners.
I actually am about to put the rims and tires up for sale. PM me if you're interested.
Old 03-03-2018, 09:25 AM
s2000Junky's Avatar
I was referring to the 8.5 +40 RPF1 option, not the 8 +45 Manga_spawn mentioned, likely just misunderstood.
The 8.5 +40 will accommodate any BBK on the market with typical 17"/325"-328"mm kit. You can run a 225 235 or 245 tire on this wheel up front. The 245 will require a little pull. Run the 9 +45 in the rear.
Old 03-03-2018, 10:08 AM
Site Moderator
Yeah mistyped. My bad.
Old 03-03-2018, 10:37 AM
flanders's Avatar
Gotcha, I did print out the template from the kit a linked to and it looks like it might actually clear the 17x8 +45 RPF1.
Quick Reply: Tire/rims size for lowered ap1 with BBK
