Tire Rotation
Old Jul 17, 2003 | 09:25 AM
SilverS2KAZ's Avatar
Default Tire Rotation
How do we properly rotate the front tires?
The wear on the outer wall s is slighly more than the inner right now, so I want to rotate.
Old Jul 17, 2003 | 09:26 AM
Murk's Avatar
You don't. The S02's are unidirectional tires.
Old Jul 17, 2003 | 09:37 AM
The Gasman's Avatar
They can't be rotated! The setup of the car is that they wear that way. Check the tire pressure and make sure its okay and that's the best you can do.
Old Jul 17, 2003 | 09:41 AM
Someone in another thread said you can dismount the tires and move them to rim on the other side. This would keep them rolling in same direction, but make the inner wall the outer wall, and vice-versa.
Can you do this?
Old Jul 17, 2003 | 09:43 AM
zzz36's Avatar
I think you are referring to xviper's post, he's the one who did it for his rear tires and I believe he says that it is perfectly fine just make sure you get the tire rebalanced.
Old Jul 17, 2003 | 09:51 AM
__________________________________________________ _______
Seems if only one person has done this, I don't want to be the second.
Old Jul 17, 2003 | 10:14 AM
Jim@tirerack's Avatar
Former Sponsor
As long as you dismount them and then point them in the correct direction you will be fine. I don't think you will come out ahead because you are going to have to pay for the mount and balance.
Jim
Old Jul 17, 2003 | 04:24 PM
mas's Avatar
mas
[QUOTE]Originally posted by Jim@tirerack
[B]As long as you dismount them and then point them in the correct direction you will be fine.
mew002
Jun 4, 2008 03:24 PM
jono
Sep 10, 2004 10:07 AM
tkdsungjin
Oct 6, 2003 06:42 AM
WestSideBilly
Jun 27, 2003 09:17 AM
Lew Hall
Feb 16, 2001 02:28 PM
