Tire Rubbing
Old Jan 16, 2006 | 05:03 PM
Touge Freak's Avatar
Default Tire Rubbing
I have 18 x7.5 and 18x 8.5 Volk CE28n and Espiler springs (1.3" drop) and are running the correct size tire (225/40/18 and 255/35/18 Nitto 555's).
I am rubbing in the front wheel well when going over uneven entrances and the weight of the car shift alot. What can I do and is thisa major problem...will it cause problems? The rubb is not that bad. Can the front fender linners be trimmed or bent?
Thanks for any help.
Old Jan 16, 2006 | 05:10 PM
VIC4UF's Avatar
what offsets did you get?
Old Jan 16, 2006 | 05:56 PM
silentdancer's Avatar
roll ur fenders
Old Jan 16, 2006 | 06:29 PM
18X7.5 +50 / 18X8.5 +52 is the wheel size and offset.
How do I stop the rubbing in the front?
Old Jan 17, 2006 | 10:04 AM
eraxpres's Avatar
you shouldn't be rubbing with those specs....check you alignment?
Old Jan 17, 2006 | 10:10 AM
turbo_pwr's Avatar
I'm willing to bet you didn't get an alignment after you installed the springs.
Old Jan 17, 2006 | 12:18 PM
Ubetit's Avatar
It's possible he's often rubbing +50 offsets with a 225 tire and a 1.3 inch drop. I rubbed those same specs on a stock height car during hard maneuvers and my alignment is fine.
Old Jan 17, 2006 | 01:41 PM
I got an alignment. The guy did not give me any numbers though.
I only rubb over big dips or bumps going 45+ and when going in steep driveways where the car rocks and shifts weight.
Suzuka_BlueS2K
Sep 7, 2013 01:30 AM
lastminute_s2k
Jul 14, 2009 07:39 AM
AkA S2K
Feb 21, 2006 09:32 AM
JUN-JUNG
Sep 12, 2005 08:41 AM
Deeguy
Oct 31, 2002 09:09 PM
