tire sizing help
Im looking at running 17x8 et 35 and 17x9 et37. Will I be able to run a 255/40 in the back, or should i stick with a 245/40? Also how many degrees camber will i have to run to have a flush look.
I come from a different scene where we run a 235 on a 10 and poke is OK! hhaha VWs
you will definately need to have your fenders rolled and rear bumper tab relocated. +37 is VERY aggressive..i doubt they will fit without extensive fender modification.
im running:
17x7+38 225/45/17 (-2.5 degrees camber)
17x9+42 255/40/17 (-4.0 degrees camber)
lowered on eibach springs and i still rub in the rear on certain bumps.
-a
im running:
-a
I don't know how much of use this would be but I fitted 235/40 on a 17x9 +47 in the front without much work, but i still need to roll the fenders and do something about the liners.
on the rears, I'm mounting 17x9 +35 with 255/40 and it juts out a good bit.. I need to drop, camber, roll and cut bumper tabs for it to fit.. maybe slight pull.
