Tire Too Big
Are you referring to width or diameter? The rear tire diameter is bigger than stock but there is nothing you can do about that if you want to run anything wider than 255. Something like a 275/35 would be perfect but there is no such thing.
They are going to rub with a 50 offset rear and probably on the front as well. There are very few tires made in a 265/40R17 size. With those wheels I would go with 225/45R17 and 255/40R17. You are still going to need to roll the fenders and run more negative camber.
