Tires for my 17-yr-old s2000
Old 09-03-2017, 09:23 PM
skidisk's Avatar
Default Tires for my 17-yr-old s2000
Hi, I need some new, grippy tires for my S2K that I just drive around on streets, not track. Anyone want to recommend good tires these days (or point me at a discussion that answers this)? I don't care if they wear out in 10k-15K miles.
Old 09-03-2017, 09:58 PM
skidisk's Avatar
I found the tire rack and will get info there. Thanks.
Old 09-04-2017, 06:44 AM
Chuck S's Avatar
Received 1,138 Likes on 1,001 Posts
OEM 16" wheels I assume? Bridgestone RE-11 are very nice and are I believe are quieter than the RE-71A tires.
Fitting OEM 17" wheels will give you more choices. For example the rear width in 16" wheels is 225mm. In 17" a 255mm rear tire will fit fine. Over an inch wider, lower profile, better handling.
-- Chuck
Old 09-04-2017, 09:25 AM
MrFunk's Avatar
Michelin Pilot Super Sport
Very grippy
Quite
Comfortable
Good treadlife
Old 09-04-2017, 11:33 AM
BallSackJack's Avatar
I order from Tire Rack more often than not, but for one more day there is a Labor Day sale at Discount Tire Direct (always free shipping).
I was able to stack rebates, so $100 off from DTD and $70 off from Bridgestone on some RE-71R's.
https://www.discounttiredirect.com/promotions/labor-day
Old 09-04-2017, 01:56 PM
importluva's Avatar
Very grippy
Quite
Comfortable
Good treadlife
+1. Very happy with mine
Old 09-07-2017, 03:19 PM
skidisk's Avatar
Thumbs up OEM-16 vs OEM-17
Thanks for the recommendations. Yes, I have OEM-16 wheels.
You are correct that I am having trouble finding available tires for them.
How difficult (and expensive) is it to switch to 17" wheels?
I like the idea of better handling.
Old 09-07-2017, 03:41 PM
TsukubaCody's Avatar
Buy Continental Extreme Contact Sport in the OEM sizing. Done deal.
Old 09-08-2017, 03:38 PM
Sylvain2000's Avatar
If you stay with the 16" you need the hardest sidewall you can find. The s-02 that came with the car were rock solid. You could roll on a flat tire. And be aware the rear 225's where as wide as 245's
Those 2 things will make the 16" great.
Or like said previously, swap to 17" and save trouble and get pretty much any reasonable tire
Hope this help ..
Old 09-08-2017, 05:14 PM
alSpeed2k's Avatar
Where are you located? Check your local forum to see if anyone is selling a set of OEM 17's where you are; alternatively, you could pick-up a set of aftermarket wheels from the Tire Rack or one of the vendors on here if you want some JDM bling.
Quick Reply: Tires for my 17-yr-old s2000
