TPMS
Do the tires have to be removed from the wheel to gain access to removing the TPMS sensors?
Also, if I get aftermarket wheels and don't put the TPMS sensors in them (or if they won't fit), then will there be a problem other than the TPMS light coming on in the dash? (I've heard that the VSA can't be disengaged, but not sure if that is true)
Last, is there a way to get the light off in the dash (pull the fuse?)?
Thanks!
Thanks!
Yes, the TPMS is on the 'inside' of the rim, so the tire needs to be removed.
If you run rims/tires without TPMS, then you'll only have the TPMS light to deal with. When I swap wheels, sometimes it comes on within a 1/4 mile of driving, other times it takes ~50 miles.
However, as soon as the rims with TPMS go back on, the light disappears on startup.
Have you tried removing the fuse to get the light to go off when you aren't running the TPMS sensors?
Originally Posted by SpooN-FED,May 27 2009, 12:49 PM
Regarding TPMS, Do OEM TPMS sensors fit into aftermarket rims. I have a set of CE28N's and wondered if I can just use the TPMS from my stock rims.
Originally Posted by Black Knight,May 26 2009, 12:54 PM
THank you appreciate it!
I do have a service manual, so I'll check to see if that fuse does ONLY the TPMS light.
I generally ignore it, as it isn't anything really serious. (FWIW, I do check my tire pressures myself, as TPMS generally won't trigger unless your tire pressures drop under 28 PSI or so... which is already way too low)
Originally Posted by psychoazn,May 27 2009, 05:26 PM
No, I havn't.
Just put aftermarket rims/tires on last week w/ NO TPMS sensors, and my light went off w/in 15 miles.
Last night, I pulled the fuse designated for the TPMS system (interior fuse box under the driver's side dash--7.5amp fuse), and the TPMS warning light is still on in the dash! Bummer!
Anyone else try this and can confirm that you got the same result?
