trackday setup
i'm thinking about this trackday tire setup :
front : advan a038 225/50/16
rear : advan a038 245/45/16
any comment ?
stiffer sway-bar like tanabe is needed ?
regards,
claudio
any comment ?
regards,
claudio
The 225/245 is effectively a reduced front/rear stagger, more tread up front, than stock. That gives more static oversteer than stock. IMO a little too much oversteer, but that's really driver preference. I run that stagger, but have a stiffer front swaybar. A custom wheel alignment and tire pressures are also other tools to adjust the oversteer/understeer balance.
Other effects of the wider front is more rubber = more braking capability on the front, which increases rear brake bias, which makes the car slightly more unstable under braking than stock. This isn't really that big of a deal since most cars have extra front brake bias for safety, which gives some margin for changing the brake bias rearward. Wider fronts also increases steering effort, but that doesn't matter because you got power steering.
superstuddc27
Mar 15, 2014 10:13 AM
turb0mister2
May 24, 2007 11:02 AM
silversonic
Oct 29, 2003 07:08 AM
